clutch help needed
mxmantater746
delaware, ohio
ok guys, i don't mean to sound like an idiot but i need some help with the clutch off set measurement on my 01 srx. i got a sno stuff clutch allignment bar but i'm not getting where to measure from, and the factory service manual tells me nothing except the off set should 13mm-16.5mm. any help would be great and appreciated. thanks
if thats the bar i am thinking of, the hooks on your tool should attach to the rear sheave of the primary and the offset is built in to the thickness of the long portion of the tool. used as a straight edge as well for alignment purposes. measure the handle looking portion of that tool and it should coincide with the offset specs of the manual. and if that doesnt feel right, try it hanging on the front sheave of the primary.
