SX_SLAYER
thanks to Mr. Sled i almost have my 2008 nytro rtx suspension mounted in my 97 sx7, i just have a few questions about it. i know this isnt the 4stroke side, but i figured id give it a shot anyways.
i have read that the nytro suspesions dont hook up the greatest. True? can it be fixed?
also ive heard people have had problems with the track ratcheting on acceleration. due to the fact that the suspension compresses and losens the track, can this be fixed w/o anti ratchet drivers?
finally. how much do these things wheely? i want to be able to stand it up, while still having trail manners. is this possible to do?
and anything else i should know about this suspension.
thanks
Carter Lentsch.
thanks
Carter Lentsch.
tcdesignguy
How far along are you into this swap??
SX_SLAYER
tcdesignguy said:How far along are you into this swap??
all thats left is mounting the right drop bracket (required) and bolt it in. it was pretty straight forward actually. i can get the measurements posted if anyone is intrested.
tcdesignguy
I know putting bender pipes on mine helped it stand right up, even when I sit on the tank... trying to go the other way and lock it down more or it is difficult to ride in the tight trails with skis in the air. I also swapped out for a Polaris Pro/X Skid at same time.
