Question for SRXRULE
mtonn
hey, i was wondering if you are still running your remote fuel adjusters. Looks like a great idea would you reccomend anything different in the fabrication process? thanks
i made a set, used lamp parts for the dials at the top and just crimped them on. for the needle conecter instead of welding i drilled a hole into the jet, drove an allen wrench into it then crimped a connector from it to the cable. used vaccum block offs with holes in them to cap the top off to make it look better.
hey thanks for the info. as far as the allen wrench in the jet, did you just drill like a quarter inch into it then crimped the wrench to the cable with a cable crimp or electrical. I was just wondering so i could do it right and have it not fall apart in the hills. thanks alot
lamp parts again, they have a brass piece about 1/2in long that is threaded for a 1/8 shaft, i think for the on nob.
i use this to crimp on to the allen wrench and the cable.
