dadonie
Instructions say to set servo by lowering idle to below 900 rpm and putting a mark on the housing and cable spool. My question is do I leave the engine running to adjust the free play to 2.5mm or have it shut off?
YA*AM*A*HEAD
shut it off
dadonie
Ok I am getting there, so does it help the performance if I adjust to the low side of the spec @ 2.0mm or at the high side @3.5mm I assume the low side will open the valve more? Or just take the middle of the spec @2.75mm?
most of us just go with 2.5mm
Use 2.5...
super1c
Super Moderator
daman said:Use 2.5...
Daman welcome back!! You know winters close now. Would never now today, 75 and sunny here. CCC
Yea same here low 70's today high 70's tomorrow,hahasuper1c said:Daman welcome back!! You know winters close now. Would never now today, 75 and sunny here. CCC
