Coolant option
srxr700
Lifetime VIP Member
cedar springs, mi
I cant seem to find 60/40 mix at any local automotive stores here in michigan. I also hate to spend the big bucks buying yamacool from my local distributor. I need to replace the coolant in both my srx and sxr so yamacool is getting pricey. Im sure somebodies ran into this.....
any silica free (almost all are) coolant, I have used both dex-cool and green to -40 with no issues. I normally run Prestone as that is what I keep in the garage. I use distilled water and cut my own 60/40
I have been using a 50/50 mixture of Dexcool and distilled water for years without any problems. I change the coolant in my sleds every season. Dexcool is made to be used with aluminum cooling system parts.
