Hey guys quick question..... I was told not to buy new reeds just open mine up all the way?? Also was told this will be fine to used even trail riding. Will there be a performance increase?? And what does he mean by open them all the way.
There is a lot of info on the website if you just search "reeds".
If your sled is basically stock and your reeds are in good shape, there is little to no improvement[on a SRX] available by doing anything other then running your stock cages + reeds. If you need to replace your stock reeds you might want to look at Carbon tech carbon fibre reed pedals as they are at least equal to the stock reeds in performance.
JM.02c
Bob
