Over the past month or so I have been reading all 650+ back pages of threads trying to learn as much as possible on the SRX. I came across a thread talking about TORS- I know it has something to do with the throttle- can someone explain further?
how does it know the difference between "stuck" wide open and "held" wide opensgauthier said:Throttle Over Ride switch connected to the throttle cable at the carbs. Cuts engine rpms down in case throttle gets stuck wide open, like when it freezes.
hope this helps
ahhhh- I seeRyan B said:It's two microswitches that talk back and forth to each other. They have to be in agreement. So if the one on the carbs is at wide open, and the one on the throttle is at half the system goes "we have an issue" and limits the rpm to 3500 or so.
srxman72 said:This system fails on a lot of SRX's, if you engine bogs and loses spark, this is usually the problem. All you have to do is unplug it because it is not necessary
srxman72 said:Yeah I just said that because last season I was dealing with the problem all winter. I would go on rides and randomly I would lose all power and it would backfire. I looked online for solutions to the problem and couldnt find anything. It was very fustrating because I not joke cleaned the carburators 5 times and replaced all the coils(with used ones of course) trying to find the problem. Finally I just brought it to my mechanic and he just unplugged the wire and said not to replace the mechanism because the only thing he said it does is when you start the sled and you happen to have the throttle wide open for some reason it will cut out spark. But obviously getting a second opinion and finding what else it does might make me want to replace it. I cant complain about the sled though as this is the only problem ive had with it at 12400 miles.
And all this time I thought they spoke Japanese . . . Now we find out it was English after all . . . or maybe a little Engrish . . .Ryan B said:It's two microswitches that talk back and forth to each other. They have to be in agreement. So if the one on the carbs is at wide open, and the one on the throttle is at half the system goes "we have an issue" and limits the rpm to 3500 or so.
