Help...
rogerz
CT
Anyone have a fuel pump hose routing diagram for a 1999 SRX700, or can anyone tell me what goes to the top most upper fitting on the pump? The motor has been out if her for some time now...
Thanks!
from 98 srx: fuel tank/flow is alone and on the right as sitting. theres an arrow on the pump indicating flow. opposite side of pump, l-r: carb 1,2,3,the 3 fittings that are closest together. should be a space and then crankcase(pulse, may be marked with a p), oil pump to finish it off.
Yes, I think it's the oil pump I was wondering about. It's the top right one sitting on sled. Thanks a lot!
