Anyone know if Bleeding the coolant in a 1999 SRX is the same as a viper. I guess the Viper has a bleed screw under the back of the seat. If so, I can't find bolts to remove the seat... any tips? Thanks!
open your rear trunk flap and the bolts on the inside bottom left and right.Instead of using the bleed screw which will make a mess of antifreeze everywhere.open your rad cap and run the motor a while and you can see the liquid circulating and this will release any air bubbles at the same time.Easier this way and less work.
