torelloracing
ok so i searched quick but came up with nothing and am in a huge rush to get my sled done and i need to install a tether , the one i have has 2 black wires but i dont know if they go to my kill switch or to the wires behind the key set up? ? ? please help if you can and sorry for posting something that is prob posted a million times>
thanks
Ronnie
grass here i come ! cant wait for the snow
thanks
Ronnie
assuming you have the correct tether, tap into the wires from/to the kill switch. they make 2 kinds, a normally open and a normally closed. usually the one for your sled has a white stripe on a black wire to correspond with the color code of the wires on the sled, based on my experience. dont be surprised if the one your trying to wire in only works with the tether removed as opposed to installed into the safety switch.
kirk700 srx
A tether is just like a light switch! you need to wire it into your ignition positive wire.Cut the wire and join the 2 black wires in series on one end of the wire and the other end completing the circuit! Clear as mud???
torelloracing
mine is PRO-DESIGN it says for battery and non battery tethering atv ,motocross,watercraft i guess no snowmobile but the guy at the store said it would work how can i tell it has one long and one short wire ? and its says short wire is ground and does not say where long one goes?
the part number is PD-102
on your sleds kill switch wiring, the all black wire is ground, the black wire with the white stripe is the power/hot. so if i am reading you correctly, the short wire would go to the all black wire and the longer wire to the black/white wire. i would make some slits in the existing wires or use scotchloks for a temporary connection for testing purposes before commiting to a more permanent cut and solder install.
torelloracing
thank you for all the help if this tether is no good they may see them at the grass drags im going to ..
thank again for the help !
madzx2
on my 2000 i used one wire to the black/white, and one wire to the black/yellow.
