Yamaha Enticer 250 oil to gas ratio
igottajob2
Minneapolis, MN
I am in the process of changing my stock carb to a 34mm mikuni. What is the oil to gas ratio for it and how do I mix the oil and gas? I can't use the oil injection anymore and do not know how to mix the two. Any help would be awesome. -Jake
Sounds good. You don't happen to know were to get a diagram of how to hook up the throttle cable properly to a mukuni do you? I have a 34mm vm carb.
