BRAAAPPP420
just bought a rear heat exchanger. im extending my track to 136 will i be able to use this still?
What kind and for what machine?
BRAAAPPP420
02 viper
BRAAAPPP420
anyone out there know if i can use this on my 02 viper with a 136 tunnel extension????
super1c
Super Moderator
Looks like stein already did it! CCC
http://www.totallyamaha.net/forums/showthread.php?t=65925&page=1&pp=10&highlight=viper+136
Which heat exchanger did you buy and what tunnel ext to you get? I used a Srx rear exchanger and a Hartmann tunnel kit. I shorten the tunnel ext. to a true 136 wich helped the exchanger to fit.
super1c
Super Moderator
stein700sx said:Which heat exchanger did you buy and what tunnel ext to you get? I used a Srx rear exchanger and a Hartmann tunnel kit. I shorten the tunnel ext. to a true 136 wich helped the exchanger to fit.
You did a nice job, this is how i plan on doing mine. Had this tread saved in my tech section. CCC
BRAAAPPP420
the heat exchanger is the bigger one and its a starting line product extension.
If the parts are similiar to what I have it should work. Might require a little creativity.
