ReaperSRX
I was thinking of making tunnel re-inforcement like in the tech section, but i was thinking how am i going to make those raised holes so i have some traction for my little booties...........James
you need a punch die set and a hydraulic press...like even a arbor type press, but you will have to make your own punch and die set.
ekimsx600
I made mine at work. I used a 1" piece of plate and drilled a hole and then I made countersink of 60* that was about 3/4". Then I went to the lathe and spun up the punch with the same 60* angle on it. Put it in the press and formed all the holes.
TopGunnSrx
gild
tool
I made a tool out of 1" round stock and a lathe. I use a i/4" X 11/2 " bolt and nut to pull the traction hole in the running boards. No need to use a press just drill a 1/4 " hole at the location you want your traction point, install tool and tighten with 7/16 wrenches and its done.If you want pictures I forgot how to post them so you have to walk me through the steps or E mail me.
I hear these work great: Punch & flare tool
Hi Gild,
How did you make the tool and hole? I'm confused on the bolt thing?
Thanks,
Thanks,
gild
Traction tool
Simple way of making traction holes, no press needed.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
how much were those piece you bought to make the holes? That looks like a great Idea because my srx has almost no traction. Please let me know of the price and where you got them. Thanks
