Stock SRX can question
KEVIN
VIP Lifetime Member
OTTAWA
Are the any differences in any stock SRX cans?
I bought a stock can for my 1998 SRX and if doesn't want to fit.
If I bolt in down all the pipes won't reach
HELP?!?!?!?!
DAMN it
Did anyone ever cross these donunts in a automotive part #
Also check to make sure all your rubber gromets are in place. Sometimes the rubbers wear out dropping the pipes into the belly pan. I have used old limiter straps before in place of the rubber if your looking for a cheap replacement!
can
On the 98 SRX you need to use a 98 srx can. Other years will not fit correctly. Find a can from a 98 and your problems will be solved.
