srxguy
Going to change my chain case oil in my 02 srx..Any suggestions to what kind or brand Is better than the others?...Thanks guys!......
Amsoil is the best, but more expensive.
i've used both amsoil chaincase oil and their synthetic gear lube (alot cheaper than the chaincase oil of theirs) , and also shell synthetic gear oil, and i've never had any trouble with any of them.
TopGunnSrx
wat is it just 80/90w? Just go to a auto store and pick up a gallon cheaper then you will for the little 8 oz bottles. Pretty much the same stuff
Blue Devil
I agree with topgun. I have used valvaline 80/90 on my 98 srx since it was new .No probelms!!
ecopter
The gears of your chaincase aren't going to care how expensive the stuff is their "gearing" through. Topgunn's right.
I compare running sythetic to someone who takes a lot of vitamins.....they're going to have the most expensive urine in the neighborhood. Basically, when you drain it at the end of the season, you'll have really expensive waste oil.
Jon
Jon
SRXPete
Have you ever seen what non-synthetic chaincase oil looks like at -40C?? (ie. 80/90). That's why I run Amsoil synthetic because it's cold up here.
screemin srx
- Nov 29, 2003
I used Mobil 1 synthetic....no problems
blue who
any synthetic and your belt will thank you in the end
SnowBandit
I run semi synthetic... It was like mud at -40... So now I am getting mobil 1 for this year..
hmm i guess mine is too thick. all i had was 85-140 esso gear lube when i assembled sled today. oh well i guess ill change it later(500km later
) after a good run or in a heated shop cause the garage was at +15c today and it poured stiff. sticks like glue to chain and gears though.
yamaholic22
amsoil gear lube
sxrextreme
gear oil
ive always run all maxima in all of my machines ....and they make all kinds of lubes .....the gear oil im using is maxima chain case lubricant extreme cold 100% synthetic ...in the green and black bottle .....and i use the tundra synthetic blend 2 cycle oil.. for oil....in the purple and black bottle ....check it out www.maximausa.com
hookedonblue
I run in mostly cold weather. but it also varies. I use "motul" i have found it to be the best and it's not bad in price for a synthetic blend. My YAMAHA dealer sells it for about
$7.50 litre. COMES IN A REAL NICE BOTTLE TOO.
Synthetic, about 3-4 dollars per oil change. And I change at the beginning of every season.
snowfoxsx
i run dextron atf fluid, never any trouble yet and ran it in all my sleds from 93 and up, flows well cold and is cheap also! no bearing trouble, leaks or chain breakage. 8000 km in one year!!
i use atf, it's a lot lighter when it's realy cold out.
700srx
- Jul 23, 2003
Gear Lube
Iam with SRXMAGIC i also use atf. Have been for the last four years. No problems yet.
good to know. gonna have to try it in et410. the reverse is a bugger when sled is cold.
atf works fine, they use it in all the stick shift trans in cars and trucks now too, simple and cheap to replace every year. type "f " is a tad thicker then dextron 2
