seanmurphy26
anyone know where i can get some heat sheilds or some heat tape for a 700 sx 98?
ekimsx600
Where do you want to use it? I used aluminum tape on the inside of my hood to help reflect the heat from the pipes.
try jegs.com or summit racing.com they have heat resistant materials
i got heat tape from menards for my belly pan
seanmurphy26
alright ill see what i can do
..SNAKEBIT..
this heat tape is that like the foil tape? ( looks like tin foil duct tape?? )
tin foil with glue on one side
..SNAKEBIT..
OK thanks I guess I got the right stuff then!
I also found some tape ( foil with 1/8" insulation and glue ) thought this would give some insulating factor and reflect the heat but dont know if it will take the heat from the pipes?? Are guys peeling off the foam? or going over it with the reflective tape??
ekimsx600
I put it right over the foam. I'll let you know how it works.
