srx rpms?
fusion 69
ohio
I have a 99 srx drag sled, what should it be pulling for rpms at 500ft.? I,m seeing 8100 right now. That is is what it felt best at by seat of the pants, just wondering if it's a little low.
Does it have aftermarket pipes/porting/racing cdi?
Is the motor healthy with good compression & no pulled thru powervalves?
Need way more info!!!!
I agree- alot of variables- You need to know where the peak power is at and then clutch to it. Test with a radar gun or timing system trying different RPM's is one way. The quickest and easiest way is to put it on a dyno to find out for sure. This will probably be the cheapest in the long run also.
Were just southwest of chicago IL. Bring your sled and we will be glad to help you tune it on our dyno. Kris 414-788-1346
sled has a fresh top end, cylinders and all. No porting, just a haircut on top.about 145lbs on all 3, also running stock exhaust.
8100 rpm is a great spot to initially start for 500' & let rpm,s climb to 8300 as you get towards finish line.
