02 viper dead #2 cylinder HELP??
sofa-king-fast
Webster,NY
Carbs have been gone through twice,tank drained and replaced w/fresh 93,replaced plugs and moved plugs problem stays on #2 cylinder ,compression even accross the board all have 145 to 149??move the coil??
I would look at:
1.)sparkplug boot(they have resistors built in and they go bad fairly often around 4-5000 miles)
2.)coil
HOLY CRAP, THERE IS A NAME FROM THE PAST!!!!! DUDE, HAD SAME PROBLEM ON A 01 SXr 700 I DID. FOUND BROKEN WIRE ON COIL RACK. CHANGE THAT RACK AND BOOTS. you coming to jiacobbe,s !! 3:16 (yammie tony)
