can someone give me a pic of cpr valve cbles loc
sxrsist
sask. canada
the instuctions are left to be desired, i think i got it right but would like to see what others did,do the valves come out of asdjustment when you reroute them? whats the best way to check them once they are routed this way?yamahas way might not be the best way with the routing this way cause they seem to be a little tighter firtting, thanks forthe help
I was wondering the same thing, step 5 and 6 seem to be doing the same thing?
in step 6 how do you route the center power valve so it travels under the center power valve cable?? with the routing I have the center cable seems to be very tight?
