yamiexciterII
What would the best way to mod out an 91 exciter II? I have ideas but wanna hear some others let me know that would be great
Mills
if you do a search on here you will find a couple of guys that stuffed SXR triples in that chassis. With a 700 SXR triple I think you would have one heck of a sleeper. Also, do an exciter rear supspension swap search and you will find a couple of guys that extended or swapped in IQ supsensions.
methanolhemi
Funds determine that. I would think nothing
shy of an old school bender avalanche triple
would do. 854cc
would do. 854cc
yamiexciterII
im not looking to swap in and out engines. But was wondering with the 570 cc engine what would be a good setup
speednutt
Get a head (& head gasket) and y pipe from a 93' Exciter SX. You will have to run 91 octain fuel but it will bring your compression from the 120 to 150psi and will make your sled alot snappier. You could change out the cylinders for the SX Model but that wont get you to much. You can also check out more at my site, www.excitersx.com
Hope to see you there.
Speednutt
Speednutt
