9801srx
any one know what the various optional front spring rates are from the part number? looking for a stiffer set or a straight rate set.8cx-23760-00-00 = ?
8cx-23760-10-00 = ?
8ch-23760-40-00=?
" "-50-00=?
" "-60-00=?
8cx-23760-10-00 = ?
8ch-23760-40-00=?
" "-50-00=?
" "-60-00=?
kirk700 srx
I have 2 viper springs over here if you want them?
not sure how much truth to this but i was told 1997/98 xtc springs are what your refering to as stiffer spring, sure someone has more details
9801srx
thanks but thats what i have . need somthing stiffer for the way i ride the stock ones are way to soft .found the info i needed in the tech pages. westbaycustoms you are right the xtc springs are straight rate 2.3kg/mm thanks.kirk700 srx said:I have 2 viper springs over here if you want them?
I have a set of 98 xtc springs. Make me an offer for them.9801srx said:thanks but thats what i have . need somthing stiffer for the way i ride the stock ones are way to soft .found the info i needed in the tech pages. westbaycustoms you are right the xtc springs are straight rate 2.3kg/mm thanks.
