VanceSrx
I have a 99 srx with a 136'' conversion and the stock kyb's in the fron. I was wondering what the best way to lift the front end, to get more travel and transfer. Any suggestions? thanks
Flip your front shock mounts and switch them from side to side,all you will have to do is shim the bottom hole with washers in behind and knotch the side a bit.You'll see what I mean if you hold one up in place,you should be able to tell where the notch needs to be and how the lower hole needs washers in back of it.
