justin1620
I am running the stock gears in my 99 srx 700 which is 23/37 w/70L chain. I also have a 39 tooth gear so i can try out a 23/39 combo to see what works better....i basically want to get max mph in 1000ft give or take a few ft. Can i use my stock 70L chain and stock 23t gear with the 39t gear? I know there is a chart somewhere but i cant seem to find it? any input is welcome.
Yea, its in the tech section under clutching and jetting...scroll down to gearing. says 70l is g2g.
i would swap out if you have not already to the stock 00-02 gearing.. their 13 wide vs 15 wide so you save rotating mass and they were geared pretty good for top end. I heard a while back the 98-99 was over geared
