WNYViper
Hey guys, not sure if it is against the forum rules, but I was just browsing the closeouts on PortYamaha's website and they have new Ohlin Shocks on closeout for the Vipers/Venoms at $400/pr... thought I'd pass it along to anyone looking to upgrade... Carver Performance is running the same deal for the 97-03 VMAX and similar sleds
http://www.portyamaha.com/eshopprod_cat_1011-3795-5301_product_1047431.GYTR_hlins_Shocks_.htm
SWEDE
Good price I wish I had an extra 400 bucks kicking around!
Truckkid42
gosh darn it i want a set. but i could put so much other stuff into the sled.
WNYViper
Got a pair of em on their way to me along with a Torque Limiter... by the time I am done tweaking this sled it will be an antique! But I have a while till the Nytro XTX's come down in price to something reasonable! lol
dude, I think the shocks wont work, the clickertop wont clear the fancy pipes on the right side.
you might have to break them down, cut the can mount off, drill tap and install a hose and mount remotely,, will look cool but a pain the ***, you have srx pipes so, your used to that already getting them in there
Millinocket Rocket
Ya- I have those shocks and it's fairly tight as it is- with the bellypan stock.... but that IS a killer deal for Ohlins w/clickers...
WNYViper
BETHEVIPER said:dude, I think the shocks wont work, the clickertop wont clear the fancy pipes on the right side.
Dangit... live and learn... anyone want to buy a pair of Ohlins for an 02-05 Viper/Venom? lol On a side note, they might work well on my wheeler, I think the length is about right, have to check it out...
Truckkid42
i'll give you 200 bucks for the set lol
WNYViper said:Dangit... live and learn... anyone want to buy a pair of Ohlins for an 02-05 Viper/Venom? lol On a side note, they might work well on my wheeler, I think the length is about right, have to check it out...
Dude, just try to get them on there before you sell them obviously. You never know, you might get them on there!!!
Mike
WNYViper
Super Sled said:Dude, just try to get them on there before you sell them obviously. You never know, you might get them on there!!!
Mike
Yea, I am going to try them, but I am pretty sure that Scott is right, the SRX pipe hangs pretty low in the shock opening
you might get them on, but the bump hitting is the problem, the cans and dial swing up.
just cut them and mount the cans on the bellypan like the snow cross sleds.
Truckkid42
or just sell the shocks to me for cheaper than what you paid
T.S.U.Filmz
they will work run them upside down so you don't have an issue
clevis mount top, eye mount lower, not to mention, it would put the plasic adjuster almose even with the bottom of the trailing arm if you could.T.S.U.Filmz said:they will work run them upside down so you don't have an issue
Just cut them
T.S.U.Filmz
oh yeah the clevis mounts i forgot i have an SRX
02VIPER ER
when you say the shocks wont work, are you saying they wont work on a VIPER? the description on port Yamaha says it'll fit an 02 - 04 SXVIPER
If it doesnt fit the Viper why would they advertise that in the discription?
If they will fit, I wished I had seen this sooner, I spent the same amount of money on the ohlins w/o the resevoir
http://www.carverperformance.com/product_info.php?cPath=103_24_133_112_57_23_21_29&products_id=76
ViperXC
I have been looking into this as well. I think they are describing the shock for the RX-1. For that price I am gonna say it is the W/O res Ohlins for the viper.
Carver is out of the Ohlins shocks, you musta got the last set.
ViperXC
WNYViper said:Got a pair of em on their way to me along with a Torque Limiter... by the time I am done tweaking this sled it will be an antique! But I have a while till the Nytro XTX's come down in price to something reasonable! lol
Did you get your shocks yet? If so can you post a pic or say if they have res. or not. Thanks
WNYViper
I have not received them yet, Im sure they will fit a stock Viper as advertised, I just happen to not have a stock Viper, when you do the SRX pipe swap, you have to cut the belly pan near the shock mount to fit the pipes under the hood, the pipe will take up the room that the shock resi would go in.
02VIPER ER said:when you say the shocks wont work, are you saying they wont work on a VIPER? the description on port Yamaha says it'll fit an 02 - 04 SXVIPER
I asked BTV about this, and it's related to the SRX pipes conversion on the Viper, which I guess entails you to modify the belly pan near the shock tower top. As long as you have the belly pan intact, there should be no problem.
