Viper Engine Mounts
SRXSRULE2
Stouffville, Ontario
Could they possibly be broken (or worn out) even though they don't seam to look like they are. Don't really want to pull my motor unless i have to, but it does seam to vibrate at idle more then others i have seen. I was thinking about a torque limiter, but that shouldn't effect it at idle.
Mine can shake like a spin cycle at times. I was worried about that too, but the guys here assured me its normal. I would say your ok. You would know if you had a bad mount as you would be tearing belts up. May want to give them a check, dont need to remove engine to do that. 2 up front and the other 2 you can see by removing the air box. Torque limiter is recomended reguardless. CCC
bulkhead behind mount
i had a motor mount that was a suspect, after pulling the motor and removing the mount, the bulkhead had torn allowing the mount to flex more that it was supposed to. a little tig welding and a bit of grinding and it is good as new.
