Would i beable to replace my stock bars with these. Im currently using a 3" riser aswell.
http://cgi.ebay.com/ebaymotors/New-...p5197Q2em7QQcategoryZ35587QQitemZ390185531799
You'll need a riser that will work with the 1 1/8 clamp area as the stockers are 3/4". You also find that the bars will probably be shorter than the stock bars so you might want a taller riser to get back to the height you are at right now. The stock srx bars have about 4.5 - 5" of rise built into them, those TAGs look to have about 2.5 or so. Might be a little more or less depending on the bend.
