crazyrunningkid
I was having trouble with my lights flickering on and off, changed the voltage regulator and now nothing will light up, dash lights, head light, tail light. I see there is another voltage regulator, should I change that as well, or could it be the stator??
98 srx 600
98 srx 600
![](/styles/vip.gif)
super1c
Super Moderator
Did you do a search? Tons of info on this. Sounds like a rub through on your wire harness. Put old regulator back on and check harness top to bottom. Most rub throughs are under engine. CCC
crazyrunningkid
it does not work with the old voltage regulator....where can i find the harness?? Or try replacing the other voltage regulator
SRXSRULE2
Unplug the voltage regulator, start the sled but don't go much above idle to prevent damaging anything. If your lights all work fine, the voltage regulator is most likely your problem.
crazyrunningkid
ok, now i see there are 2 regulators there, I replaced the smaller one, anyone know which regluator controls what??
