power diff
00sxrjoe
Maine
Whats the power difference between a srx600 and sxr 700? I know a sxr 700 is around 115hp.
fourbarrel said:
Unless I miss my guess the SRX 600 is supposed to be around 120-125 hp where the SXR 700 is like you said 155-118.
Ya I thought they were close. 155 would be nice. HAHA I know you ment 115
owned em both or actually way more then 1 of each
600 srx = 124 hp at 8300 rpm
700 sx-r = 114 hp at 8500 rpm.
In an actual drag race they are way closer then hp shows!!!
I wanna try a 8df-10 clutch set up off a srx 600 on a sxr 700.
The 700 sxr comes with 8df weights & it overrevs badly just like the 600 srx did.
I have posted this set up on here about 5,000 times & a search would find it
change inner rivet to 4.5 grams
Run a 8bvfa 4 stroke helix
rpm,s are bang on.
Just for you it,s been posted 5001 times. Please learn to use the search function.
