Older SLP triples
JohnnyQuest
Minnesota
I came across a set of older SLP triples with individual silencers for my wife's 01 SxR 700..... looking for some jetting and clutch set ups for them....... Anyone have a baseline for those pipes??
More then likely not exact for power inc specs but the bender specs for their triple pipes are
150 mains 52.5 pilot 1.5 turns out on fuel screw
or did you happen to take the time to call slp or visit their website? they used to have the info on there and as knowledgable as they are i would think someone would have the info your looking for.
here ya go:.......0- 5000 ft. ele.---
primary spring- blue white blue primary weight-8cr-13.3mm rivet inside hole 10.3 outside
sec.cam-45 degree
sec. spring-green (std) [preload-1-6
gearing std
carbs.....
stock pilots
needle-6dgm5 #3 E clip
needle jet stock
slide- stock
fuel screw-1.5 turns out
air jet stock
mains
0 -2000 ele=0 to 20 degrees =147.5 across the board
