quick ?
360miller
muncy pa
i just bought a 1.25 ripsaw for my 2000 sxr 600 the clutch and gearing is stock do i need 2 gear it or tune the clutch i know these overev and was told that 3.6 grams inner and outer and that should take care of the revs but will my track change it again any help will be appreciated
with that track gear it down 1 tooth upper.Clutches will be more efficient running then.I am running 3.6 in both holes also to stop that over-rev on top.
thstorms said:
what were you running before???
I wouldn't think you should have to change it......
the sled was stock but now it has head gasket mod along with reed notch and the 1.25 ripsaw
so gear it down to 19 tooth? and run 3.6 in both holes
