Where does the washer go?
PurePower
Minnesota
I have an 02 Viper and replacing the secondary shaft bearings and have a question. On the chaincase side there is a c-clip on the shaft, then is it a washer, brake rotor, spacer, seal, bearing etc or does the washer go someplace else? Between the brake rotor and the spacer on the chain case side? I have the microfish on the parts, but don't seem to match up with the parts i have. Any help appreciated.
Which one?
There should be two washers in the area you are talking about. One goes in between the clip on the shaft and the brake rotor and the other heavier "spring washer" goes on between the top gear and the big nut that holds the top gear on.
Hope this helps.
Madmatt
