Joatmon
Exciter Gods,
I'm thinking of throwing Exciter II suspension into my 88' Exciter...anybody know of any issues with this that I should be on the look out for..?
Thanks folks!
-Joatmon
Thanks folks!
-Joatmon
I think the mounting points were different... might be some redrilling in order.
Joatmon
cool...It looks like better suspension so I figure it's worth some drilling..!
Vmax540
The 87-90 Exciters had a progressive dampening link suspension simular to the Phazer. The 91-93 Exciters used the original Pro-Action used in many sleds up until ~1996. The Pro-Action was king of ride up until Polaris came out in ~1993 with the Extra 12 & 10 long travel rear suspensions.
Finding Rear Suspension Shocks
Search all the following sleds had the original Pro-Action Rear Suspension.
1983(?) to 1991 SRV 540
1983 to 1991 Vmax 540
1991 to 1993 Exciter
1992 to 1997 Vmax 750/800 with the exception of the 97 XT models
1994-1996 Vmax 5/600 with the exception of the 96 XT models
KAYABA INDUSTRY CO. LTD
Front of Rear suspension middle shock ~ 119/16" or 295m.m. C.C.
Rear ~ 14.5" or 366m.m. C.C.
1992Vmax4 Rear KYB 13D P# 8AX-47480-00 Infinate Preload
?Year Vmax540 Front/Middle KYB H22 P# 8V9-47481-00 Infinate Preload
?Year Vmax540 Rear KYB 2610 P# 8U7-47480-00 5 Position Preload
1985 Vmax540 Front/Middle KYB WF8 P# 8V9-47481-00 Infinate Preload
Kimpex Pro Gold Rear P# 04-284 Infinate Preload
Joatmon
Thanks! So I should be able to just swap out the shocks and springs or would I need to find the whole rear suspension setup?
Vmax540
The 87-90 Exciters had a progressive dampening link suspension simular to the Phazer. The 91-93 Exciters used the original Pro-Action = Two totally different suspensions.
Joatmon
Perfect! just what I needed to know...many thanks!
moto403
Try to find a polaris xtra10 or edge skid to put under it and you won't regret it. i yanked my sxII skid last year and would've gave it away after riding on the new xtra10. it's a world of difference
crfbikerboy
moto 403, how much moding was involved in that swop...it sounds good and I have an extra 10 at home looking for a sled to fall into... I own a 93 sx....just not into a big mod project, but would like more suspension for my bad back.
crfbikerboy said:moto 403, how much moding was involved in that swop...it sounds good and I have an extra 10 at home looking for a sled to fall into... I own a 93 sx....just not into a big mod project, but would like more suspension for my bad back.
You just need the measurments for the mounting hole locations from the Polaris. Measure back from the flat side of the hex drive shaft and down from the top of the tunnel for each hole. Then measure it out on your sx and drill holes. MEASURE TWICE DRILL ONCE! You may need to do some grinding or shimming of the shafts that go up into the tunnel to fit it in nice but if I remember correctly they are the same width or pretty close.
Joatmon
Sounds like I have a couple options. My 88 Exciter is a great lil' runner but the rear suspension is crapola so I was looking to improve the ride a bit. I'll keep my ears/eyes open for original proaction or Polaris X-10 stuff....we'll see...!
Thanks!
Thanks!
