2004 Viper Mountain Jetting Question
toolman11k
Minneapolis, MN
Cleaning the carbs on a 2004 Viper Mountain, and it has 156.3 Jets across the board.
I assume on a viper like a SRX, the mag jet should be bigger?
Does anyone know what the stock jets are supposed to be, I live in MN and do not ride high altitude.
I think the altitude around here is roughly 950'
nope
the book calls for 156.3 and 45 pilots jn 3.0 and 1 7/8 ps for 300-1700 feet.
142.5 with 5o pilots is what i used to run at sea level....you are incorrect in that the viper doesnt run staggered jetting because the head has staggered compression.
Thanks,
Did the bigger pilots help any starting / idle issues you had with 45 pilots and bigger mains?
What was the reason you switched from stock?
