Any advantage to coating stock exhaust on viper?
yamaha09
michigan
Was wondering if there was any advantage performance wise to getting the stock viper exhaust coated?
If your trail riding your sled the advantages would be an easier to clean pipe, Less corrosion at the weld joints where rust usually forms on the pipe and your pipe should heat in faster and be on target for the powerband at a sooner time(not really noticable trail riding). It will also give your sled a cleaner under hood appearance.
If you have your pipe coated what color are you going to shoot for? I had mine done in what is called cerma-chrome (JET HOT).
