Just got srx few questions how to Jack it up?
shock720
toronto
Okay I just got a 2000 srx, I was looking at my track and noticed on the inside of the track the vary middle row of where I guess like rubber notches is looks like they were all ripped off? And okay second how do I lift my snowmobile to it's like all yours in your photos all jacked up? Mine has the ohlin suspension
check the limiter strap bolts- make sure they are not put in backwards. When the suspension compresses, the end of the bolt/nut can rub on the track. Made this simple mistake on my M10 and shredded most of the rubber nubs you are talking about
like viper700t said - most skids have a carriage bolt with smooth head on it - this end should be facing the track and the end of the bolt/nut should be towards the inside of the suspension - can't quite remember for sure on a stock yam skid, but that is how the M10 is set up
Thanks now I know what I'm lookinbuford I just looked and my strap bolts are horizontal and couldent be hitting the middle inside of my track, I noticed there is like 2 14 bolts on the side of the tunnel and there is a contraption that goes through the middle of the track there is a piece that has like a gold colure to it and has like a semi circle like a D shape comming off it does this rotate if I loosen the 2 bolts?
