Aftermarket RPM Tach (Install?)
bojisrx
iowa
Does anyone know what wires are what on the stock RPM tach? Also Can i splice most aftermarket 5" RPM performance Tachs into a stock one and run it like this ??? Or What do you recommend doing?
are you thinking about using one for a car? if so it would have to be programmed for the correct tach pulse. you prob would need to run a battery as well.
