Truckkid42
im installing my handlebar risers tonight and i've got everything done but the oil extension cable. i see that there is no easy way to get to the bottom of the cable. anyone know how to switch the oe cable out for the longer one without tearing the motor apart??
mattyg1405
how big of a riser i did not have to extend mine with i think a 2-3/4" riser it may have been 3" im not positive
I pull off my right hand side motor mount to get at mine on my srx
Truckkid42
lol, i got a 6 inch riser with a pivot adapter, so in total im like 7.5 inches. ![Smile :) :)](https://totallyamaha.net/images/smilies/smile.png)
mattyg1405
oh yeah im of no help here haha
09xtxrider
Where did you get your brake line and throttle extensions from?
Im gonna be doing the same thing shortly....is there anything else you had to replace?
Truckkid42
i got everything from dennis kirk:
riser block
yamaha pivot adaptor - u want this so your bars can go straight up, not angled.
brake line extension
throttle/oil line extension
riser block
Truckkid42
still need help guys, winters coming soon ![Smile :) :)](https://totallyamaha.net/images/smilies/smile.png)
On both my sleds I had to pull the motor mount that sort of sits over the pump. Then it was easy-peezy![Smile :) :)](https://totallyamaha.net/images/smilies/smile.png)
Wayne084
How did you make out TruckKid? I have to do the same thing tomorrow.
Yes pull the motor mount, and stand on your head. Just be patient and it will go fairly easy. It is a bit hard to get to.
Wayne084
Well I got it done. I took out the air box, the carburetors and that motor mount like everyone else said and it was a piece of cake (In hindsight anyway). Thanks for the help.
One other thing, I know this is an amateur question, but I don't want to risk it. How much slack should I allow in the oil line? Make it so the pump just hits full tension at full throttle, or so that the tension just barely lets off at idle or something else?
