fortress
Hi!! After installing a new ripsaw and my new mbrp canister, i discovered that my rpm now reach 8800 8900 !! i dont think its good?? My clutch and my secondary are totally stock. The gearing too!!
what i do to solve this????
what sled do you have?
To get rpm,s down you must add more weight to the primary clutch. Adding a steeper helix will help too.
S
srx_eh
Guest
You want to get some weight in that primary.
How many miles on current components? How is it backshifting? May have some wear and tear issues(binding) of the secondary also. Before making any clutching changes make sure all components are working as they should and your not making changes to overcome deficiencies in the clutches. Seems obvious but your sure it's not a track spin issue?
Using an old belt will also cause sled to overrev.
fortress
yamahay said:How many miles on current components? How is it backshifting? May have some wear and tear issues(binding) of the secondary also. Before making any clutching changes make sure all components are working as they should and your not making changes to overcome deficiencies in the clutches. Seems obvious but your sure it's not a track spin issue?
humm! i don't have any backshifting!!! my primary clutch component seems to be good!! So, i just need to add weight?? What the setting you suggest.. I really dont know how many weight is required to drop the rpm!
fortress
how many grams i need to add to reduce by 100rpm????
I'm wondering if the problem came from my gearing!?? Because of the ripsaw?? Maybe dropping one teeth will solve this?
fortress
Which hole need to be filled???
B2SO
- Aug 18, 2003
To Lower Rpms
The tip , the farthest away from were it mounts to the clutch
fortress
well, my dealer did found that my secondary bushing are worn out!! just hope this is real reason why my rpm and top speed was not good!
Kind of what I figured. I've had the same problem in the past. The thing about worn bushings is as they wear the performance drop-off can be so gradual you don't notice until it's a real problem. Sled should feel way more responsive when you gas it or get in deep snow with the secondary working 100% again. That's why I asked about the backshift, when the secondary binds the rpm will slowly increase instead of jumping up to full shift RPM when you nail it.
fortress
yep, you were right cuz i had no backshifting at all, even with the angle at 80!!
My sled will be ready just monday, they don't have all the parts in the store.. Just hope the sled will run ok after that!!
yamahauler78
You will need to add weight, if the exhaust can gives any kind of HP it will cause the sled to over rev which means you are not utilizing the HP the can is putting out. Exhaust cans and clutching goes hand in hand
