anyone ever seen sno stuff rumble packs for an srx?
Spinner18
Virginia, MN
i had a member send me pics of some sno stuff rumble pack silencers in which he claims is for an SRX, and i've never seen or heard of sno stuffs for an srx. the are triple silencers, and each is individual and not welded together in anyway from what i can tell. if someone could post the pics for me, I can email them to you so you can see. curious if they are legit or not... and yes, they have snostuff right on them.
I have never sean sno stuff for srx it sounds like hauck or bender stingers
they are triple stingers. i have pics, hopefully will be getting some of them installed this evening also from the seller. i'm tempted to just buy them because i've never seen a set :)
They will sound cool. Sno-stuff has good sounding cans IMO. My guess is that it will sound like hauck's growlers.
awesome. the only thing i noticed with them, are they are missing a few spring tabs, which i would expect from usual sno stuff quality lol.
does anyone have some spring tabs I could weld on, or know what I could use for those?
Just get a small piece of flat stock steel and weld them on, just like the stock SRX setup.
then just drill a hole for the spring to hook into? what thickness flat stock you thinking? and i'm wondering if i would have to curve the steel to the shape of the exhaust to get a good weld around the outsides.
Ok, in your 2nd post you say that the bodies are aluminum.......so, how do you plan on welding steel spring brackets to aluminum? Also, I doubt they are aluminum, as sno-stuff wouldn't go that "all out".
the bodies are aluminum, the necks and elbows off each to the exit and pipe are steel. whats your email i'll send pics!
