I have a '99 SRX how do I find out if the crank weld recall was made on this sled?
Dealer
If the actual recall was done by a Yamaha dealer then any dealer should be able to put the vin # in the computer and let you know. If it was welded by someone other than thru the Yamaha recall program then you are only going to find out by tearing it apart. Check the crank run out and if it is within spec RUN IT! Many of them never developed a problem.
Madmatt
Madmatt
The only one I saws just had a vibration in the handle bars all the time. I then rode my buddys and his was smooth as glass.
kirk700 srx
Take the crank out, In between the connecting rod journals there will be a bead about an inch long. you cant miss it!
