Swapping Skis?????
Stiffhorn99
Mid West
I have a pair of oem skis off my 07 phazer. I just bought a 99 Indy 340, it has metal skis that are toast.
My question is, could I use my yams on the polaris????
Check your spindle width, if the Indy spindle will fit, check to see if you need a washer/spacer,also you might need different rubber pieces, that the spindles sit on.
Its worth a try, they would be a nice upgrade.
