justin1620
hey guys, going through the pre season maintenance and am changing the chaincase oil. Most of it spilled on the garage floor when i pulled the drain.....does anybody know how much it takesto refill the case with fresh oil. I have a bottle of amsoil synthetic chaincase oil but its only 12oz (355ml), would this be enough? thanks........LET IT SNOW!!!!!!
8.5oz. I belive if you look in the tech section under specs that info would be there
madzx2
i use 8 oz in my srx
musselman
around 250 ml
kirk700 srx
I use a full bottle of Amsoil 355 ml beter more than not enough in a chaincase!
![](/styles/vip.gif)
8 oz is all she needs ,any more and you may blow the seals..like kirk always does..loll
mattyg1405
what is the bst oil to use? i HAVE to service mine it looks nasty...
Spinner18
any is fine if you change it regularly which it should. can use polaris chaincase lube, yamaha chaincase, cat, doo, amsoil. even 80-90 works just fine. most of it is just over priced
