01 venture 700 temp light flashing
Diesel n Dust
Northern Canada
I recently checked the clutch on my buddy's venture and found nothing wrong after disassembly. Just a bit of dirt and lack of maintenance. so when i put it back on the sled and fire it up the engine temp light flashes 3 times quick then a delay, 3 times quick then a delay....e.t.c so i try the sled and it seems to run fine other than this flashing light.
can anyone tell me what this means or where to get a flash code chart ?
sounds like a temp sending unit code. wiggle the wires on the plug on top of the head and see if it goes away. i have had several issues with the wiring harness plug having a wire wear in the plug.
