New tunnel and skid
mm700sledr
Helena, Montana
I just found a complete tunnel, track and skid from a 2001 Polaris 800 159" for a very cheap price and wanted to know what it is gonna take to put it under a 99 Mountain Max 700
You more than likely won't be able to use the tunnel from that sled, but to put the skid under it you will need to know the mounting locations from the donor sled (the 01 Polaris 800). You'll need distance from drive axle to front mount, top of tunnel down to front mount, and then same thing for the other mounting locations.
Depending on the lug height and pitch of the track you may need to change drivers for it. If the lug height is too tall it won't fit unless you drop and roll the chaincase. You would also need a tunnel extension for your MM, and you may want to gear it down possibly as well.
