cleaned powervalves
bigd1000rr
Montgomery, IL
Ok cleaned powervalves 2day but did not adjust them just put them back in. Will I be asking for big trouble if I do not and go back and adjust them? I am a newb with the srx so dont know much about them other than reading this site
i would adjust them ....or you will probally be sending them to me to fix the pull thru in a month or so ...
Yes, you should take the small amount of time to adjust them to make sure the cable is not too tight. It is easy to do, just need to take your time and use the process shown in the Tech section.
Give it a try and if you run into any problems, just let us know. We will happily guide you through the process. Everyone on this site enjoys helping each other out.
ok did all the steps shut motor down at 900 rpm feels like there is no room for adjustment. Cable is tight but not real tight
Ok guys thanks for all ur help, I feel like a dummy was pretty easy now just need snow to get revenge on my sea-dont buddy who beat me last yr on his mxz 800 when i had 2 of the 3 polits blocked an 1 main and dirty powervalves.
