yammyhamer408
hey guys doing some work on a 08 nytro rtx and my friend droped off a track for me to install and was wondering if it was goig to fit the track is off one of the factory yamaha mod nytros. does any one know the track profile and what is need to make it fit in a stock nytro other then smaler drive sprokets
Stock drivers are 9 tooth 2.52 pitch.
What exactly do you need to know & you should be asking this on the 4 stroke side.
yammyhamer408
i dont have a acount for the 4 stroke side i just need to know if it will fit with only 8 tooth extroverts and drivers.
grapeape
Yamaha uses 2.52 and 3.0 pitch stock, there is a noticable difference in the distance between the lugs between the 2 pitches. Ski-doo is running a 2.86 pitch track, but I doubt Yamaha would run that pitch on a race sled. You can post a pic of both tracks side by side if your not sure, also there is a part number on the track, see if it cross references to the numbers on tracks usa website.
yammyhamer408
ok thanks guys ill see what i can get i still have no resived the track from the guy yet all i know is its off of a factory yamaha race sled so ill check tthe part numbers and see what it is. thanks for all the help
yammyhamer408
got the track tody and its a 1.5 ripsaw snocross track with 96 studs and we are running 9tooth drivers is it gona clear the heat exchanger at the front ?
