Truckkid42
i've had my viper apart for about 2 months now doing this and that. just put it all back together and put a silencer on it. started it up and there seems to be a puddle of oil right under the exhaust every time i start it up. is it because i've had the exhaust apart and sitting in a bunch of wierd angles?? mind you i have not touched the motor at all.
flatblack97
Did you fog the sled before parking it for the summer? Fogging oil usually finds its way out through the exhaust, especially if your like me and are generous with it.
Maybe check your oil lines. you were working on your oil cable so maybe something around there is leaking now.
since you added your bar riser and such is the oilpump cable releasing the oilpump arm or is it holding it open further??,because this will make it richer all the way thru
