Well, the only reason I mentioned the crank is because in 2008 I had a relay that blew from a wire under the engine going bare from vibration and grounding out. In order to get the sled home I had to unplug the relay, otherwise it would only start up and idle, but stall as soon as any throttle was applied, some saftey feature by Yamaha I guess. So anyway, with the relay unplugged you lose your lights and tachometer. As chance would have it, my water pump let go on the way home and siezed the engine. If the relay was plugged in, the temp light would have come on and it could have been prevented. So it was first rebuild in 2008, just the top end. The shop told me thats all that was needed ($1500 bill). Then it blew the head gaskets the next season in 2009, so back to the shop it went, a different shop because the first shop screwed me. The 2nd shop told me the first shop screwed me and it should have had the crank replaced in 08. So they replaced the crank and bearings, pistons, rings etc ($2000 bill). Now this year I performed a compression test and found the compression to be 105, 125, 100. Since the 2nd shop has gone bankrupt, I took it to a brand new Yamaha dealership to have it checked out, the one techician that works there is the guy that rebuilt the engine at the 2nd shop and said all they did was rings and gaskets, no crank, no new pistons nothing, just rings and gaskets. So that turned out to be rip off no.2. Now this Yamaha dealership says it needs another rebuild which will cost $2000-$3000 to do it right.
So thats why I want to just buy a nice stock engine thats never been apart, and stick that in, do normal maintenance and enjoy this sled for once.
The 2001 SRX 700 engine with 7000kms, has a price tag of $1000.
If its a direct replacement like everyone says it is, I think this is the best option for me right now. I love the SRX, and plan on keeping it forever so just selling it because it has cost me so much money is not an option.
I guess what I need to know right now is, has any one on this forum installed a 2001 srx engine in a 2000 srx? And if so did you run into any problems what so ever? Or is it just plug and play?
