motorhead327
I need to know the distance from ground to bottom of frt bumber on a stock suspension 700. Thanks
motorhead327
Bumpety Bump
What type of surface is it on ,,,,uphill or down......
whammy..you forgot to say sinkhole...
motorhead327
It is sitting flush on the concrete right now.
Iv seen them any where between 8 - 16 inches.... All depends on set in, and shocks used,,,, standard will be around 14" with weight of sled (with set in) to bottom of bumper.... Depending ..........
whammy..the height on mine is 4 inches off the ground..what you talking about??????LOLL
motorhead327
Thanks for the response! Im at 14.5 with viper trailing arms/stock shocks with fresh charge/good amount of spring preload. Think I was around 12in before. bluemonster1 glad u got the 600 going good.
No wonder it doesn't work.....hehahaohhahum That only causes pull troughs,,,,bluemonster1 said:whammy..the height on mine is 4 inches off the ground..what you talking about??????LOLL
troughs????????????huh!!!!!
bluemonster1 said:troughs????????????huh!!!!!
Whats a trough blue?????...
whammy's word..not mine..lol ask him??
