SRX ski problems
99srxguy
minnesota
I have a 99 srx 700 and when i push down on the front bumber, the ski tips go out and away from each other. like they are both trying to turn to the outside. is this normal or what can i do to fix this? any input whould be much appreciated
that is the norm.The ski's are toeing out when they do that.So when you set up your ski's for proper toe-out..make sure tank is full,equivalent weight is put on the sled that represents you fully geared .Then adjust toe-out.
